Found this in the respository, as in Octoprint my temps always go away while printing. (and this fix definitely fixed the display tempeature in Octoprint. But..
Just a heads up, not sure if it is for sure related to this plug-in for sure or not, but I had JUST installed this and never seen this before. 3 or 4 print attempts in a row with the cgode (I opened in in textpad) set for the hotend temperature of 205, Octoprint kept trying to set my temperature to 260.
Thanks for the reponse just finished reassembling my hotend to make sure nothing was melted or damged as that seemed pretty hot. I disabled the plug-in for now, and loaded just the standard xyz cube and it loaded fine. I want to try again after this calibration print is done with the plug-in enabled and disabled.
If you, as Charlie suggests, upload the logs, the plugin will output what messed up temperature it reads, and then what it parses it to, and sends to OctoPrint. If the error lies with the plugin, the logs will tell.
I have personally tested the plugin on 3 different Ender-3 v2's, and all seemed to report the right temperatures.
@AlbertMN Seems from your plugin source that would only be reported at debug level, which most users don't have - so that might not be useful in this case. And it seems unlikely to me that your plugin is to blame for this. But we shall see...
A quick test with the Ender-3-v2-Temperature-Fix plugin disabled STILL did it with this specific gcode. which was generated using the same CURA as all my other prints. So it doesn't appear to be plugin related. (At least this plug-in)
Sorry for pointing fingers so quickly, just NOTHING else had changed other than this gcode file and the plugin.
Different plugin, definitely then. Comparing the gcode, it goes from M104 S205 in the file you supplied, to M104 S410.000000 in the serial.log. Only thing in the way is a plugin.... but which...
@derekpurdy Well, glad to hear that this isn't a problem with the plugin, as it's been pushed to quite many users already. You seem to be in good hands though ^
Yeah, I appreciate its a long process. I had to do it for an issue I had before, and did take a while. But, you can live with the fact you may help someone else who has the problem. At least we know we're barking up the right tree.
