ERROR: Failed building wheel for Octolapse
Been trying to install Octolapse. I have Octoprint on an android phone and navigating/installing through my windows computer. Here is a snippet of the error message that I get.
note: This error originates from a subprocess, and is likely not a problem with pip.
Building wheel for Octolapse (setup.py): finished with status 'error'
Running setup.py clean for Octolapse
Failed to build Octolapse
Installing collected packages: Octolapse
Running setup.py install for Octolapse: started
Can somebody help? I have installed python on my windows computer, but am a complete noob when using it.
Here is the final error message that I get.
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
Running setup.py install for Octolapse: finished with status 'error'
Error!
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
same problem here did you find a solution
Same Problem for me :sob:
Just to be sure - you're also using octo4a?
Yes i am using Octo4a on a Samsung s10e. Plug in Extras are also installed. I tried top find Help on tiktok and Made a Video of the Error Code, If you might Take a Look :pray: ich Versuche mittlerweile verzweifelt octolapse in octo4a zu installie... | TikTok
lol nah
I have never and will never use use TikTok.
Did you check the octo4a github page?
If nobody else reported that issue - you could report it.
I have already searched forums for a solution, but so far, I haven't found a concrete solution. I was hoping that someone on TikTok might randomly come across my issue and has a solution :sweat_smile:, because I first learned about octo4a on tiktok. Unfortunately, I also didn't find anything on GitHub, even though the problem has been mentioned there as well.
I'll check my current smartphone in the coming days to see if there's a compatibility issue with the S10e. But i Thing i did nothing wrong during the Installation😭
Octo4a on discord:
Okay, I found Octo4a on GitHub, but no specific solution to my problem. The issue with the error message when installing Octolapse in Octo4a seems to be widespread, but so far, I haven't been able to find a solution anywhere.
Btw. Octo4a ist working fine. But it is impossible for me to Install octolapse in Octo4a. The Installation allways breaks with the following Error:
octolapse unable to build wheel...
Hmm I googled a bit and you're definitely not alone with this issue
Seems like an Octolapse issue.
The only solution I was able to find is this forked and patched Octolapse plugin
Try to install the zip via the plugin manager.
Ha :partying_face:, it worked!! Thank you so much!
going into the android app, then into settings, install the plugin extras
Worked for me!
Hello @Arnav_Gupta !
Thank you for your input, but did you notice that:
  1. The last post is over a year old? - and
  2. This thread is marked with a solution?
