hi, i tried to instal octolaps with octo4a and its giving me some errors
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [1146 lines of output]
likely tags: v0.4.3
picking v0.4.3
got version from expanded keyword {'version': 'v0.4.3', 'full-revisionid': '8d53c91069943b9b4d78498c2fc225b3d6d04cb8', 'dirty': False, 'error': None, 'date': '2023-05-13T12:58:31-0500'}
Argon2 passlib backend is not available, not using it for password hashing
/tmp/pip-req-build-a16q48xz/setup.py:58: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
if LooseVersion(octoprint.server.VERSION) < LooseVersion("1.4"):
Found packages: {'octoprint_octolapse_setuptools', 'octoprint_octolapse.test', 'octoprint_octolapse'}
error: command '/usr/bin/gcc' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> Octolapse
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
