we all do these sort of things, it a real learning curve at times
I have had my printer a year and still learning things about different materials etc and things I can do with octoprint, Cura etc
Even I've connected printer and Rpi with usb to usb cable,I'm still getting same kind of errors.
I used usb 2.0 output. I've also checked dmesg again.
This is the last 20 comment I've got.
[ 58.956435] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8000 00000000 crc 8c
[ 58.968060] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
[ 122.377750] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4000 00000000 crc 46
[ 122.390657] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
[ 173.153240] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c000 00000000 crc ca
[ 173.165447] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
[ 249.613042] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2000 00000000 crc 23
[ 249.624523] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
[ 313.455224] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a000 00000000 crc af
[ 313.466622] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered.
[ 351.423282] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6000 00000000 crc 65
[ 351.436207] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered.
[ 391.933718] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e000 00000000 crc e9
[ 391.945878] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered.
[ 454.955223] w1_master_driver w1_bus_master1: Attaching one wire slave 00.1000 00000000 crc 9d
[ 454.967119] w1_master_driver w1_bus_master1: Family 0 for 00.100000000000.9d is not registered.
[ 494.094813] w1_master_driver w1_bus_master1: Attaching one wire slave 00.9000 00000000 crc 11
[ 494.106406] w1_master_driver w1_bus_master1: Family 0 for 00.900000000000.11 is not registered.
[ 569.170738] w1_master_driver w1_bus_master1: Attaching one wire slave 00.5000 00000000 crc db
[ 569.182243] w1_master_driver w1_bus_master1: Family 0 for 00.500000000000.db is not registered.
[ 620.837803] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d000 00000000 crc 57
[ 620.850733] w1_master_driver w1_bus_master1: Family 0 for 00.d00000000000.57 is not registered.
[ 647.430260] w1_master_driver w1_bus_master1: Attaching one wire slave 00.3000 00000000 crc be
[ 647.442150] w1_master_driver w1_bus_master1: Family 0 for 00.300000000000.be is not registered.
[ 696.520184] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b000 00000000 crc 32
[ 696.532280] w1_master_driver w1_bus_master1: Family 0 for 00.b00000000000.32 is not registered.
[ 735.607635] w1_master_driver w1_bus_master1: Attaching one wire slave 00.7000 00000000 crc f8
[ 735.619065] w1_master_driver w1_bus_master1: Family 0 for 00.700000000000.f8 is not registered.
[ 787.540762] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f000 00000000 crc 74
[ 787.552124] w1_master_driver w1_bus_master1: Family 0 for 00.f00000000000.74 is not registered.
[ 849.868610] w1_master_driver w1_bus_master1: Attaching one wire slave 00.0800 00000000 crc c2
[ 849.879953] w1_master_driver w1_bus_master1: Family 0 for 00.080000000000.c2 is not registered.
[ 902.945989] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8800 00000000 crc 4e
[ 902.957368] w1_master_driver w1_bus_master1: Family 0 for 00.880000000000.4e is not registered.
[ 940.918328] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4800 00000000 crc 84
[ 940.931342] w1_master_driver w1_bus_master1: Family 0 for 00.480000000000.84 is not registered.
[ 991.445859] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c800 00000000 crc 08
[ 991.457424] w1_master_driver w1_bus_master1: Family 0 for 00.c80000000000.08 is not registered.
[ 1068.041811] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2800 00000000 crc e1
[ 1068.053161] w1_master_driver w1_bus_master1: Family 0 for 00.280000000000.e1 is not registered.
[ 1131.501127] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a800 00000000 crc 6d
[ 1131.512641] w1_master_driver w1_bus_master1: Family 0 for 00.a80000000000.6d is not registered.
[ 1195.211099] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6800 00000000 crc a7
[ 1195.222668] w1_master_driver w1_bus_master1: Family 0 for 00.680000000000.a7 is not registered.
[ 1235.644233] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e800 00000000 crc 2b
[ 1235.655920] w1_master_driver w1_bus_master1: Family 0 for 00.e80000000000.2b is not registered.
[ 1298.820944] w1_master_driver w1_bus_master1: Attaching one wire slave 00.1800 00000000 crc 5f
[ 1298.832350] w1_master_driver w1_bus_master1: Family 0 for 00.180000000000.5f is not registered.
[ 1338.034011] w1_master_driver w1_bus_master1: Attaching one wire slave 00.9800 00000000 crc d3
[ 1338.045554] w1_master_driver w1_bus_master1: Family 0 for 00.980000000000.d3 is not registered.
[ 1387.370587] w1_master_driver w1_bus_master1: Attaching one wire slave 00.5800 00000000 crc 19
[ 1387.382104] w1_master_driver w1_bus_master1: Family 0 for 00.580000000000.19 is not registered.
[ 1439.435474] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d800 00000000 crc 95
[ 1439.448407] w1_master_driver w1_bus_master1: Family 0 for 00.d80000000000.95
This is the Terminal tab when I've try to connect.
Connecting to: /dev/tty1
Changing monitoring state from "Offline" to "Error: Connection error, see Terminal tab"
Unexpected error while connecting to serial port: /dev/tty1 SerialException: '[Errno 13] could not open port /dev/tty1: [Errno 13] Permission denied: '/dev/tty1'' @ comm.py:_openSerial:2611 (hook default)
Why is it still denying access?
I've also tried ''ttyUSB'' or ''ttyAMA0'' things.
Pretty much that dmesg output means that Raspbian and the Pi can't see your plugged-in printer as a device. Assuming that the printer is plugged in and you've got a data type of serial cable then I'm not sure what to tell you. If Raspbian can't see it, OctoPrint can't talk to it.
As I understand from the forums, this problem became nightmare of the users. I haven't seen anybody that faces problem like me and managed to solve it.
It helps to indicate "Ultimaker 3 Extended" when searching the Internet, btw. This forum area seems to include a number of people who have theirs working both from the Cura plugin to OctoPrint and from OctoPrint itself. You might ask them there.
tty1 is a tty on your pi itself, not a printer. It should show up as either ttyUSB0 or ttyACM0. If it doesn't because the underlying operating system doesn't even recognize the printer as a serial device (which your dmesg output looks like) then there is absolutely nothing I can do about it. I strongly suggest following the suggestion of @outsourcedguru and seek help from people who actually own the printer and have gotten it to work with OctoPrint. I'm not one of them and apparently no one here is either. I'm not even sure if the UM3 by default even does support a regular serial connection or if you might need to have to modify it somehow, I remember it having its own thing.
And please do not open bug reports on the tracker for what is obviously a clear support request.
I've found the problem. Ultimaker 3 series does not work with OctoPrint because of disabling USB slave relation.
People seem to think that between cura and the ultimaker cloud you shouldn't need octoprint for remote control https://github.com/foosel/OctoPrint/issues/2288#issuecomment-543739609
Guess ill never get Octopi working ever again?
I ran into the same thing!
I think you can do
sudo usermod -a -G tty yourusernamehere
sudo usermod -a -G dialout yourusernamehere
found on Octoprint on Kubuntu - Permission Denied /dev/ttyUSB0 - #2 by jneilliii
