I have {% snippet 'doSmartPreheat' %} in my Before print job starts GCode scripts. While tracking down an unrelated problem I wanted to disable this, rather than delete it (I sooo lazy) I commented it out with a semicolon. Semicolon is ignored, smart preheat is performed.
That would be a user issue here, unfortunately. The plugin 'Smart Preheat' and it's gcode script would inject something with multiple lines - I don't know what they are, so here's an example:
M104 S200
M109 S50
M140 S200
In your gcode script, you have this:
; {% snippet 'doSmartPreheat' %}
When rendered, it will end up looking something like this:
; M104 S200
M109 S50
M140 S200
So the comment is only in front of the first line.
If you want to comment out the template-stuff, then you must wrap it like this: {# <thing> #}
The documentation for the Jinja2 template engine is below:
Jinja β Jinja Documentation (2.11.x) (palletsprojects.com)
Small correction, rather use this documentation:
OctoPrint still relies on an older version of Jinja because they changed behaviour in a backwards incompatible way at some point (classic case of an undocumented but widely used feature turning out to actually be a bug).
That was changed back in 1.4.1, we're on the latest Jinja release that still keeps Python 2 around
Damn... I totally forgot about that one
Thanks for the correction
Thanks guys, perhaps a small lesson for me not be be so lazy
