Greetings all- I had an instance of Thermal Runaway error overnight on a long print. When the system halted, no more data updated the tempgraph. Too much time had passes and the graph cache scrolled out of range so I don't know if the error was for overtemp or undertemp.
Logs only say-
"2018-09-01 10:19:38,195 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Thermal Runaway, system stopped! Heater_ID: 0"
Is it possible to take a snapshot of the tempgraph or get a dump/status on the terminal output at an occurrence like this? A little bit more information would go a long way to diagnosing the problem.
thanks in advance
