I didn't see a category for feature requests, so i'm posting under general.
It would be real handy if we could create macro scripts that would allow us to give reasonable names to the various gcode and firmware commands, and to be able to add one or more commands to a given macro.
Hello @jsimmonstx!
You could do this with this plugin:
Ok, no macro names then, but a button to click.
Technically you could do it just by editing the custom controls in config.yaml, or use the Custom Control Editor plugin (part of the above linked plugin) that occasionally will wipe out all the ones you added. I recommend if you go that route to disable the plugin after saving to avoid that from happening.
