I'm using Octoclient on my iPhone. Which spool will be selected when I start a printjob remotely?
In the app there is no option to select a spool. Or is there no support as printing from SD?
Thanks in advance!
Thanks in advance!
I'm guessing you'd need to take this question to the author/vendor of the iOS app itself. Since there's no open-source repository all we could do here is guess.
I would guess that it will select whichever hotend is included in the gcode file from your slicer. If you have an extra plugin to manage filament spools then your iOS app is probably clueless about a setup like that.
Further, I would doubt that the author would add print-from-SD support since not everybody has that on their printers.
