Right now, OctoPrint only pauses because Marlin follows up with a backup pause command
Is there a reason there isn't a filament runout script configureable under settings > gcode scripts that runs when filament_runout is received?
action commands are supposed to be specified in the gcode spec.
that plugin is nice I was trying to get it working yesterday but was having issues with it interfering with the pause action command that comes right after
got a source?
Right, so OctoPrint will catch //action:* and do something if supported as well as pass it along for plugins.
Currently core handles start, cancel, pause, paused, resume, resumed, disconnect, sd_inserted, sd_ejected, sd_updated.
What your looking to do would need to be handled by a plugin at this present time. Handling out_of_filament might be kind of tricky since it's thrown before a pause action.
