Filament Sensor to Pushover - missing link
Hi all
Using a direct drive extruder and wanting to add a filament runout sensor to the Raspberry Pi.
I see a plugin ( Octoprint-Filament by MoonshineSG ) which will detect the sensor switch signal change on the Pi GPIO pin, and issue a 'pause print' instruction to the printer.
I also see the plugin 'Pushover' to send notifications.
What I can't find is a way to link a Pi connected runout sensor to Pushover.
I do NOT want to pause the print when the sensor triggers - I want only to send the notification via Pushover, so I have about 3 - 4 minutes to get to the printer, load new filament, and do the manual filament change when I am ready.
Is there a plugin that would either :
  1. monitor the Pi connected sensor and issue an M300 gcode to the printer ( i assume there is some kind of buffer stream that is used to queue code to the printer ) ? This would activate the Pushover plugin to detect the M300 and send a notification on the Pushover service.
    or
  2. modify the Pushover plugin to monitor, and react to, the Pi connected sensor ?
