I have a cataloged of gcode files I print on demand on one of many OctoPrint instances (Same server, I would probably design the solution to work on multiple OctoPis). They are updated on occasion, usually when I need to change the slicing strategy. I want to have central storage for the gcodes and easily send the correct version to a printer.
I have some thoughts on how to achieve this. I could use some direction on where to start.
Some thoughts I've considered :
A]
Git repo the gcodes
Keep central on server with linux Inotify -> copy to each Watched folder - > delete file on print to keep old versions
Alternately some system to compare hashes
B] write a new plugin to use a central file source like File Manager with remote (I tried a symlink in the .octoprint/uploads folder without success)
I'll test that out. When I tried copying the files directly into the folder, [ cp ~/sliced ~/.octoprint/uploads] the files would show but I could not recognized as machine files. I'll try on a fresh install.
@Adam_Kickham I created a plugin and I've described it here, btw. It appears to behave nicely (on a Raspberry Pi 3B as server) and uses the symlink approach.
I have a 3TB network drive attached to a pi3b that I named "Samba-Pi" (I'm so original) that I have no problem transferring files into and out of using the octoprint interface without having to edit anything
It's nothing but a shared network drive that I keep movies, music, and stl's and gcode on, and I haven't had a problem
