jesus
October 25, 2019, 7:30pm
1
What in the sweet jesus is a firmware update folder?
LPC1768 Configuration
The only required setting is the path to the firmware update folder. If using usbmount it will probably be /media/usb .
I have a flash drive in the pi with the .hex and related tft source, I have mounted it to media/usb, what's next?
ok so I did the usbmount thing, allowing for writing permissions to media folder
but I am getting board reset failed errors @gloomyandy
I don't own a LPC1768 based board but isn't the firmware stored on the sd card or the sd card used to flash the firmware?
Wouldn't it be easier if you just copy the firmware onto the sd card?
jesus
October 25, 2019, 9:06pm
3
right, but the sdcard has to be plugged into the printer right?
yeah but I mean to remove it, copy the firmware on it and put it back in shouldn't take much longer as using the firmware updater or am I wrong?
No just with a card reader and your pc? Which firmware are you using? Smoothieware ?
Just to be sure - you got a LPC1768 based board like a MKS SBASE, right?
I run usbmount on my Raspberry. As a result, I end up with a series of mount points like this:
ls -R /media
/media/usb0:
/media/usb1:
FIRMWARE.CUR config
/media/usb2:
main.py boot.py
/media/usb3:
/media/usb4:
/media/usb5:
/media/usb6:
/media/usb7:
It usually also mounts the SD card in the Smoothieboard itself as one of these as well as the microSD card in the PyBoard that's also attached. The usb1 here would be the card in the Smoothieboard.
So, having installed usbmount, you would want to determine into which location the Smoothieboard's SD card is mounted on the Pi and then update that plugin's settings, presumably.
jesus
October 25, 2019, 10:50pm
8
ls -R /media
/media:
firmware.bin usb usb0 usb1 usb2 usb3 usb4 usb5 usb6 usb7
/media/usb:
/media/usb0:
/media/usb1:
/media/usb2:
/media/usb3:
/media/usb4:
/media/usb5:
/media/usb6:
/media/usb7:
I unplugged the tft touch screen from the mobo, I also tried manually flashing the board with arduino ide
Ah. I think you need to configure usbmount.
sudo nano /lib/systemd/system/systemd-udevd.service
PrivateMounts=no
Reboot.
It might instead be...
MountFlags=shared
It all depends upon your version of usbmount.
afaik LPC1768 based boards are not supported by the arduino ide
jesus
October 26, 2019, 3:30am
11
managed to get it manually flashed with arduin-ide set to mega2560
That worked?
Which board is it again?
jesus
October 26, 2019, 4:04am
13
mks gen l, should have specified that sooner
Yeah that would have helped because your board is mega2560 based which is 8bit and we thought it's a newer 32bit cpu.
Basically everything we said wasn't meant for your board
i can't get mine to work.
I do a ls -R /media and i get this
pi@octopi:~ $ ls -R /media
/media:
/media/usb0:
/media/usb1:
/media/usb2:
/media/usb3:
/media/usb4:
/media/usb5:
/media/usb6:
/media/usb7:
I check my printer and it sees the files on it.
Please help
As suggested earlier, it may be easier to:
Shut down the printer
Physically remove the SD card
Put it in your workstation
Review the files there
