I'm running the latest Octopi on a Raspberry Pi 3 with 7" lcd. I'm using the YouTubeLive plugin to stream my 3d prints, but the bitrate keeps dropping, rising and dropping, etc. I connected an ethernet cable, just to confirm this wasn't a wireless connection issue. I'm running a Logitech C922 with [camera_usb_options="-r 1280x720 -f 10"]. When I do a speedtest on the pi, I get Upload: 11.79 Mbit/s give or take a few decimals. I run 'top' and the results are below..
Any ideas?
From YouTube's LIVE STREAM
11:27 AM OK Video output low
The stream's current bitrate (687.00 Kbps) is lower than the recommended bitrate. We recommend that you use a stream bitrate of 2500 Kbps.
The audio stream's current bitrate (0) is lower than the recommended bitrate. We recommend that you use an audio stream bitrate of 128 Kbps.
11:27 AM Good Stream is healthy
Stream health is excellent.
11:25 AM OK Video output low
The stream's current bitrate (698.00 Kbps) is lower than the recommended bitrate. We recommend that you use a stream bitrate of 2500 Kbps.
11:25 AM Good Stream is healthy
11:17 AM OK Video output low
The stream's current bitrate (703.00 Kbps) is lower than the recommended bitrate. We recommend that you use a stream bitrate of 2500 Kbps.
11:15 AM OK Video output low
The stream's current bitrate (708.00 Kbps) is lower than the recommended bitrate. We recommend that you use a stream bitrate of 2500 Kbps.
11:13 AM Good Stream is healthy
From 'top'
top - 11:27:34 up 36 min, 1 user, load average: 0.77, 0.86, 0.60
Tasks: 123 total, 1 running, 79 sleeping, 0 stopped, 0 zombie
%Cpu(s): 21.5 us, 1.9 sy, 0.0 ni, 76.0 id, 0.0 wa, 0.0 hi, 0.7 si, 0.0 st
KiB Mem : 896668 total, 361780 free, 240908 used, 293980 buff/cache
KiB Swap: 102396 total, 91644 free, 10752 used. 576464 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1749 root 20 0 170596 18656 8560 S 56.3 2.1 6:51.57 ffmpeg
402 pi 20 0 265972 65584 8396 S 34.1 7.3 8:17.64 octoprint
451 pi 20 0 52272 9644 8816 S 0.7 1.1 0:08.96 mjpg_streamer
753 pi 20 0 538804 120560 97384 S 0.7 13.4 0:16.13 chromium-browse
2046 pi 20 0 8108 3140 2660 R 0.7 0.4 0:01.82 top
8 root 20 0 0 0 0 I 0.3 0.0 0:01.37 rcu_sched
316 avahi 20 0 6536 3208 2796 S 0.3 0.4 0:02.17 avahi-daemon
584 haproxy 20 0 12148 6840 2036 S 0.3 0.8 0:07.32 haproxy
1498 root 20 0 0 0 0 I 0.3 0.0 0:00.18 kworker/3:0
1903 root 20 0 0 0 0 I 0.3 0.0 0:00.96 kworker/0:1
