Fusion 360 Script add in
I use Fusion from Autodesk, I have their 1.2.1.120 (current) add in for octoprint. I used to be able to use this. Now I can't connect to octoprint, current version, I always check. I generated new keys for Curra (it works) and for Fusion, but fusion won't connect. the. NEW api key is the same in Octo as it is in fusion. I've used this regularly. Same procedure for curra it works. I've recreated the key several times... any ideas?
