Alexus
February 15, 2020, 9:53am
1
Hi All,
Using the GCode section in Octoprint instead of in my cura files. I put the follwing in:
When i started the print it didn't do the nozzle wipe or ABL, So my guess is that it didn't work at all.
I removed all G Code from Slicer too so it literally just started printing. I think there must be somethign wrong with how I enetered the code.
Help would be great
Can you share the complete code you put into the boxes?
I assume there is no heating up the printer.
BTW: these codes really belong into the slicer because this one can select the correct temperatures for the filament you use.
I do not have a start code in OctoPrint, just a short one for the end:
G28 X0 ; home X axis
G1 Y180
M84 ; disable motors
M117 Print finished
Also, I would not home the printer when it's paused. You can't go on with the print after that pause. You may have a look here: https://docs.octoprint.org/en/master/features/gcode_scripts.html
Alexus
February 15, 2020, 10:09am
3
That's great to hear thank you ! You're absolutely right. thinking about it, it might also crush the print?
How does it know which filament i use?
Start :
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G28 ;Home
;G29 ; Auto bed leveling
;M500 ; store mesh
M420 S1 Z5 ;Enable ABL using saved Mesh and Fade Height
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
END:
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positionning
G1 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
Thanks for your help. I'm new to GCode....evidently
You are welcome.
Yes, when using G28, the printer goto to zero on all axes. This can result in conflicts with your print.
You select the filament in your slicer: PLA, PETG, ABS etc... these need different temperatures for extrusion and the heat bed.
Alexus:
Start :
G28 ;Home
;M500 ; store mesh
As I see in this, there are no commands to heat up the nozzle nor the heat bed. So the printer can't print anything.
For more information on gcode you may have a look here: https://reprap.org/wiki/G-code
Alexus
February 15, 2020, 10:32am
5
Appreciate it thank you. It did however do the print just none of the start or end code in octoprint. I ended up with a calibration cube at the end. odd
The red underlines are from your browser's attempts at helping you to spell correctly, I'd guess.
Alexus
February 15, 2020, 10:45pm
7
Appreciate it thanks, thought it might be some kind of intellisense.
