Update to previous post. It seems the plugin, while being recognized according the log file, is not actually running in Octoprint. I do not get any indication that the development environment is active either (I am expecting to see (venv) at the git bash prompt as shown in the tutorial documentation. When I re-run the plugin install it get a windows access denied error. I clipped the output below. Any help would defitnitely be appreciated.
Engineer@Leonardo MINGW64 /c/Devel/octoprint (master)
$ octoprint dev plugin:install
>> c:\python27\python.exe -m pip install -e .
Obtaining file:///C:/Devel/octoprint
Installing collected packages: OctoPrint
Found existing installation: OctoPrint 1.3.6
Uninstalling OctoPrint-1.3.6:
Successfully uninstalled OctoPrint-1.3.6
Running setup.py develop for OctoPrint
Exception:
File "c:\python27\lib\site-packages\pip\basecommand.py", line 215, in main
status = self.run(options, args)
File "c:\python27\lib\site-packages\pip\commands\install.py", line 342, in run
prefix=options.prefix_path,
File "c:\python27\lib\site-packages\pip\req\req_set.py", line 795, in install
requirement.commit_uninstall()
File "c:\python27\lib\site-packages\pip\req\req_install.py", line 767, in commit_uninstall
self.uninstalled.commit()
File "c:\python27\lib\site-packages\pip\req\req_uninstall.py", line 142, in commit
rmtree(self.save_dir)
File "c:\python27\lib\site-packages\pip\_vendor\retrying.py", line 49, in wrapped_f
return Retrying(*dargs, **dkw).call(f, *args, **kw)
File "c:\python27\lib\site-packages\pip\_vendor\retrying.py", line 212, in call
raise attempt.get()
File "c:\python27\lib\site-packages\pip\_vendor\retrying.py", line 247, in get
six.reraise(self.value[0], self.value[1], self.value[2])
File "c:\python27\lib\site-packages\pip\_vendor\retrying.py", line 200, in call
attempt = Attempt(fn(*args, **kwargs), attempt_number, False)
File "c:\python27\lib\site-packages\pip\utils\__init__.py", line 102, in rmtree
onerror=rmtree_errorhandler)
File "c:\python27\lib\shutil.py", line 261, in rmtree
rmtree(fullname, ignore_errors, onerror)
File "c:\python27\lib\shutil.py", line 266, in rmtree
onerror(os.remove, fullname, sys.exc_info())
File "c:\python27\lib\site-packages\pip\utils\__init__.py", line 114, in rmtree_errorhandler
func(path)
WindowsError: [Error 5] Access is denied: 'c:\\users\\engineer\\appdata\\local\\temp\\pip-wzfuld-uninstall\\python27\\scr</code>ipts\\octoprint.exe'
