Does the "Action Commands" plugin only work with some firmware?
Is there a M118 command that works with the Stock CR-10 Firmware? Or is the "Actions Command" plug-in not compatible?
Send: M118 //action:done
Recv: ok
Recv: echo:Unknown command: "done"
done is configured as a system command in "Action Commands" plug-in.
