Hey Guys
I am trying to print this part but part is not sticking to bed. I tried increasing bed temperature to 55C still no help. any solution for this issue?
Increased bed temperature to 55C.
I am using 3DOS platform for printing. It already has plugin for Octaprint. My printer is bambu P1S. Filament is nuamakers PLA+
Hello @FaultyCarry !
Do you really think this is an OctoPrint issue?
You may check the proper first layer distance.
Also the bed has to be clean, no fat or grease.
Clean your bed with IPA when it's cold (cold is important)
Youvdidnt mention which filament you're using but rule of thumb is 60 for place 70 for petg and 100 for abs
White filament is often even trickier.
I would go with 70 for the first layer and then down to 65-60.
If nothing works use a glue stick
Edit: just noticed that you mentioned pla+. My bad
Hey @Ewald_Ikemann ,
Good Day.
I am aware this is not OctoPrint issue.
Increasing temperature has fixed the issue for me.
Thanks for your help
Hey @PrintedWeezl ,
Thanks for your advice, It helped me fixing the issue.
Bed temperature of 65C did the job. maybe I will try again with 70 see if anything changes.
JR1957
July 18, 2024, 6:36pm
7
I use 75 degree bed temp for PLA and 90 for PETG and ABS. Everything sticks fine if the bed is cleaned with isopropil alchohol.
