I have a helper script I am running with p = Popen(['python', 'monitor.py'])
How can I find the path to my plugin's static or home folder?
Since it is also Python, why not just import monitor and then call a function inside the script? Running subprocesses can be a lot more likely to go wrong or be generally more fiddly. If it must be run as a separate process, then use the multiprocessing module.
If you want to find the folder that the __init__.py file is in, then inside that file you can do:
import os
path = os.path.dirname(os.path.abspath(__file__))
cool plugin project BTW...adafruit fan controller.
