well as the title suggests i need a hand trying to set the number or probe attempts for the plugin bed level visualizer.
I'm tired of spending 5 minutes using my auto bed level just to figure out my z offset is wonky and needs to be re-tested over and over til i get it right.
tldr: i want to set a 4 probe mesh instead of the 16 probe mesh
You more than likely will have to compile/flash your firmware to change the number of points to probe. Linear leveling has an option, but most stock firmware from manufacturers enable bilinear, which does now.
