Is there a way (plugin) which can use humidity sensor placed inside the dehydrator to control the on off relay (for switching dehydrator) so that filament can be kept at optimal humidity (and esentially dry).
Does it let the control via humidity only?
I've not completed it yet, but am working on a dry box control just using a sonoff relay flashed with tasmota and temp humidity sensor. That way all control rules are handled locally by the device and not dependent on the pi or a plugin.
Appreciate your reply.
Appreciate your reply. Looked into enclosure plugin. Unable to find humidity based trigger in the settings.
