hello guys
I am working on a project to collect data from Octoprint for my internship,
but i can't test my code on 3Dprint because of containment,
the objective is sent the information retrieved from the API to a mongodb database
the information i need is:
- printing id
- the file name to print
- file size
- filament consumed in mm
- how long the printing
def get_data_printing(self):
address = self.address
headers = {
'X-Api-Key' : self.api_key,
'Content-Type' : 'application/json'
try:
settings.logger_global.LOGGER.info("Printing: Requête envoyé au octoprint")
reponse_job = requests.get(address+"job", headers=headers, timeout=(4, 5))
except requests.exceptions.Timeout as error:
settings.logger_global.LOGGER.warning(error, exc_info=True)
return ["Printing: Erreur la requête get prend trop de temps"]
if reponse_job.status_code == 200:
try:
data_job = reponse_job.json()
except RequestException as error:
return ["Printing: Erreur l'adresse renvoie un status code 200 mais ne renvoie pas de json"]
except JSONDecodeError as error:
settings.logger_global.LOGGER.info("Printing: Requête reçus avec succès")
return [
self.printing_id,
data_job['job']['file']['name'],
data_job['job']['file']['size'],
data_job['job']['file']['date'],
data_job['job']['filament']['length'],
data_job['progress']['printTime']]
erreur = 'Printing: Erreur voici les codes de réponse {:d} {:d}'.format(reponse_job.status_code,
reponse_printer.status_code)
settings.logger_global.LOGGER.warning(erreur)
return [erreur]
please, do you find that good? i need your ideas and your opinion
