Currently I am testing my plugins against OP 1.4.0rcX and Python 3.
Some of my plugins are related to other plugins to I check the availability like this:
if "preheat" in self._plugin_manager.plugins:
plugin = self._plugin_manager.plugins["preheat"]
if plugin != None and plugin.enabled == True:
... do some usefull stuff with the plugin ...
Now I realized that only checking against "enabled" is not enough, because the "preHeat-Plugin" is currently not Python 3 compatible.
Questions:
- Why is the plugin still enabled and not disabled if incompatibility is detected?
- In the Plugin Manager UI the plugin is still listed, but could not be used. Only in the octoprint.log it is reflected. Is it planed to improve the UI as well?
Bye,
Olli
If compatibility is not detected it should not load and thus stay disabled.
