Hi there,
I have an existing raspberry pi running on octopi OS, am i able to install home assistant onto it without a touching my current setup?
Many thanks (:
Hi there,
Many thanks (:
Not quite. Afaik it's also using port 80 - the same port Octoprint uses.
You have to change on of the ports by hand.
One easy way to run it on you pi with another port would be to use the Home Assistant docker container.
thanks for your reply, could u point me to a tutorial installing the docker container? Sorry im new to all these
Do you just need help with the Octoprint docker container or with docker in general?
If you know docker this guide should probably be enough
with docker he cannot install the supervisor but only core...without addon...
but hoass use 8123 port...
where use port 80?
Well if it doesn't use port 80 everything is alright, isn't it? ![]()
Not sure why I thought it uses port 80 back then
I'm not an expert of hoass, but when i must to display dashbord I must enter the address xxx.xxx.xxx.xxx;8123 on my broswer
I don't know if there are other hoass services wicht work on 80 port... you know it?
