I'm new to development, so I'm starting here.
I started playing around with Twitch's Developer Rig, and I don't see why someone couldn't add an extension that mimics or pulls the gcode viewer and webcam from an Octoprint. I would like to do this so that it appears in a pop-out like the Destiny 2 extension (called a component extension per Twitch, basically a sandboxed iframe). Writing some code to show the live cam is easy, but I'm not sure on how to proceed with the GCODE viewer?
Ways I have thought about doing it:
- Use get or scrape the HTML to get the content inside the tab and use the existing .js scripts in my test Octopi.
- Stream the terminal live via some sort of tunnel and build my own viewer (wayy difficult and would be off time).
- Just scale an Octoprint window to fill in the area.
I'm not finding much, but I was hoping that someone might have tried to either use the built-in rendering in Octoprint or made their own. Any hints or ideas totally welcomed. If anyone is curious about the Twitch Extentions, here's the dev page: https://dev.twitch.tv/docs/extensions
