is it possible to use Octoprint to monitor an Ender 5 Pro,
so just mirror the screen of the printer with the funktionality
i have if stand in front of the printer? (included the video funktion)
I am a beginner and want to use the printer software first.
To clarify what you want - you want to be able to basically use and view the printer's built in LCD remotely?
If that is correct, then that will be impossible. The printer's firmware does not provide anywhere near enough information to replicate what the screen does.
However, I don't see a need for that. If you were to use software like OctoPrint (none of the host software will allow you to do exactly what you want), they include everything that you can do on the printer screen, just in a different way.
I'm afraid you (still) don't know how this all works.
Your printer will always need it's firmware to run.
OctoPrint can access the printer by connecting to the printer's USB port.
OctoPrint sends the print commands that are interpreted by the printer's firmware to move the printhead/bed/extruder.
You are right, that was a point where i was unsure. "Thank you very much for the clarification".
I already tested OctoPront (OctoPi) and it's been going well so far.
