I'm looking for a plugin similar to a filament manager to estimate print time for each of your nozzles to the filament wear factor on the nozzle. Adding another attribute to my filament library and using that with each nozzle in my library to calculate when a tolerance is closer to needing to be checked for real time wear and possible replacing.
It doesn't exist (published) at the moment, but that doesn't stop you from having a go at creating it yourself
Though it might be a more complex idea to start out learning OctoPrint plugin development with.
