When trying to update my vanilla 1.4.2 Octoprint running on Octopi (Pi 4B)'s Filament Manager Plugin to the latest version, the following error is given:
Now updating Filament Manager to 1.6.2
/home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install >https://github.com/OllisGit/OctoPrint-FilamentManager/releases/latest/download/master.zip --no-[...]
ERROR: Command errored out with exit status 1:
command: /home/pi/oprint/bin/python2 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip->install-m3M3oY/psycopg2-binary/setup.py'"'"'; file='"'"'/tmp/pip-install-m3M3oY/psycopg2->binary/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', >'"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install->m3M3oY/psycopg2-binary/pip-egg-info
cwd: /tmp/pip-install-m3M3oY/psycopg2-binary/
Complete output (23 lines):
running egg_info
creating /tmp/pip-install-m3M3oY/psycopg2-binary/pip-egg-info/psycopg2_binary.egg-info
writing /tmp/pip-install-m3M3oY/psycopg2-binary/pip-egg-info/psycopg2_binary.egg-info/PKG-INFO
writing top-level names to /tmp/pip-install-m3M3oY/psycopg2-binary/pip-egg->info/psycopg2_binary.egg-info/top_level.txt
writing dependency_links to /tmp/pip-install-m3M3oY/psycopg2-binary/pip-egg->info/psycopg2_binary.egg-info/dependency_links.txt
writing manifest file '/tmp/pip-install-m3M3oY/psycopg2-binary/pip-egg-info/psycopg2_binary.egg->info/SOURCES.txt'
Error: pg_config executable not found.
pg_config is required to build psycopg2 from source. Please add the directory
containing pg_config to the $PATH or specify the full executable path with the
option:
python setup.py build_ext --pg-config /path/to/pg_config build ...
or with the pg_config option in 'setup.cfg'.
If you prefer to avoid building psycopg2 from source, please install the PyPI
'psycopg2-binary' package instead.
For further information please check the 'doc/src/install.rst' file (also at
https://www.psycopg.org/docs/install.html).ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full >command output.
The update did not finish successfully. Please consultoctoprint.logand >plugin_softwareupdate_console.logfor details.
Anything else I could do other than ignoring the update? Rebooting has not helped.
