Change the SSID of the 2. add 24 after the name of the 2.4ghz and 5 after the 5ghz ssid... then just use the ssid of the 5ghz in the wpasupplicant file
there is a known issue with the Pi4 and the 2.4GHz wifi. If you havent disabled the HDMI, you need to force it to a lower than 4K resolution or it interferes with the 2.4g wifi
Thanks for the suggestion on renaming Both of my channels. But as stated before I am not redoing my entire network for 1 device. My printers are Less than 10 feet from my Wired Rack I will hard wire them before I Rename my 2.4 channel.
