I already have a working Octopi on my Anycubic Kossel delta printer. I just found out about the Klipper plugin and it sounds perfect but I've never played with configuring firmware. Is it plug&play? If not, how would I learn what to change? I've watched a few youtube vids about the subject but the specific configuration for my printer is still something I can't find. Where should I start?
In the readme you found a link to the DOC and installation Guide.
Christian
I've swapped in 2208 stepper drivers. Is there something I change in the config to account for this?
I appreciate the hard work you and all here have done for us.
If you use the TMC2208 as 1:1 replacement... no.
If you use the TMC2208 in UART Mode ...yes please see also the the adv Config:
Great! Last stupid question: if I am totally inept at installing OctoKlipper, can I easily revert back to my stock firmware?
Hello.
Stop the klipper service and disable it. After this you can flash any FW you wish
I just followed the instructions and installed the Klipper plugin on my Kossel but it won't connect. Looking in the Klipper settings under configuration, there is nothing there. Completely empty! What did I do wrong?
Check your Klipper log (/tmp/klippy.log) Most of the times, you'll find what's wrong reading it. And it'll also help you to provide useful information so people can help you.
I don't find the file you referenced. Here is the log from today which does show some errors:
2019-09-23 01:07:09,405 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-09-23 01:07:10,164 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2019-09-23 01:07:10,199 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-23 01:07:12,308 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 26 hook handlers
2019-09-23 01:07:12,540 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-09-23 01:07:12,565 - octoprint.server - INFO - Intermediary server started
2019-09-23 01:07:12,566 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-23 01:07:13,167 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 26 hook handlers
2019-09-23 01:07:13,206 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-09-23 01:07:13,748 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-09-23 01:07:13,814 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-09-23 01:07:15,307 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-23 01:07:16,782 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-09-23 01:07:16,784 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-23 01:07:16,784 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-23 01:07:16,789 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2019-09-23 01:07:16,939 - octoprint.plugin.core - INFO - 17 plugin(s) registered with the system:
| OctoKlipper (0.2.5) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_klipper
| OctoPrint Anywhere (1.0.16) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere
2019-09-23 01:07:16,956 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-09-23 01:07:16,966 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-09-23 01:07:16,981 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-09-23 01:07:17,888 - octoprint.server - INFO - Shutting down intermediary server...
2019-09-23 01:07:18,367 - octoprint.server - INFO - Intermediary server shut down
2019-09-23 01:07:18,370 - octoprint.events - INFO - Processing startup event, this is our first event
2019-09-23 01:07:18,370 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2019-09-23 01:07:18,379 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-09-23 01:07:18,418 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-23 01:07:18,641 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-09-23 01:07:18,896 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-23 01:07:19,311 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-09-23 01:07:19,312 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-09-23 01:07:19,339 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-09-23 01:07:19,352 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-09-23 01:07:19,365 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-09-23 01:07:19,382 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-09-23 01:07:19,478 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1569197238884 (fe80::c3e:ac66:cea7:29da) 31.24ms
2019-09-23 01:07:19,522 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-23 01:07:20,220 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-23 01:07:20,375 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:20,381 - octoprint.server.views - INFO - Preemptive cache not active for path /, ui _default and data {'query_string': 'l10n=en', 'path': u'/', 'base_url': u'http://octopi.local/'}, signaling as cached
2019-09-23 01:07:20,749 - py.warnings - WARNING - /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere/config.py:53: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
self.__items__ = yaml.load(config_str)
2019-09-23 01:07:20,859 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:21,565 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-23 01:07:21,618 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-23 01:07:21,649 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-23 01:07:21,720 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-23 01:07:26,409 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-23 01:07:26,456 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-23 01:07:26,535 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-09-23 01:07:27,092 - octoprint.plugins.anywhere - WARNING - {u'mjpeg_stream_tier': 6, u'UserId': 31638, u'camResolution': u'medium', u'name': u'My First 3D Printer', u'flipV': False, u'octolapseOptedIn': None, u'recordTimelapse': False, u'rotate90N': False, u'token': u'0U5I00DJTNSDHWBTLLQXT6UBB3RB2QKM', u'lastSeen': u'2019-09-23T00:07:00.682Z', u'flipH': False, u'updatedAt': u'2019-09-23T00:07:00.682Z', u'deletedAt': None, u'rotate90': False, u'id': 41985, u'createdAt': u'2019-09-08T15:14:02.129Z', u'subscription': u'free'}
2019-09-23 01:07:27,192 - octoprint.plugins.klipper - INFO - Added klipper serial port /tmp/printer to list of additional ports.
2019-09-23 01:07:27,764 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 15}
2019-09-23 01:07:29,356 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.13', 'ram': 918188032, 'octopi_version': '0.16.0', 'version': u'1.3.11', 'pip': '19.0.1', 'cores': 4, 'freq': 1400.0, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'os': 'linux'}
2019-09-23 01:07:34,112 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:34,187 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:34,879 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:07:34,992 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:07:35,867 - octoprint.server.util.sockjs - INFO - User jkhood logged in on the socket from client fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:53,553 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 47.59ms
2019-09-23 01:07:57,733 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 46.39ms
2019-09-23 01:09:02,498 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 45.84ms
2019-09-23 01:09:03,888 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 48.41ms
2019-09-23 01:09:13,682 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 46.12ms
2019-09-23 01:07:30,663 - octoprint.startup - INFO - ******************************************************************************
2019-09-23 01:07:30,665 - octoprint.startup - INFO - Starting OctoPrint 1.3.11
2019-09-23 01:07:30,666 - octoprint.startup - INFO - ******************************************************************************
2019-09-23 01:07:30,734 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2019-09-23 01:07:30,800 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-23 01:07:34,051 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 26 hook handlers
2019-09-23 01:07:34,309 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-09-23 01:07:34,354 - octoprint.server - INFO - Intermediary server started
2019-09-23 01:07:34,354 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-23 01:07:34,954 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 26 hook handlers
2019-09-23 01:07:34,994 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-09-23 01:07:35,512 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-09-23 01:07:35,598 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-09-23 01:07:37,464 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-23 01:07:39,071 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-09-23 01:07:39,072 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-23 01:07:39,074 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-23 01:07:39,079 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2019-09-23 01:07:39,091 - octoprint.plugin.core - INFO - 17 plugin(s) registered with the system:
2019-09-23 01:07:39,109 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-09-23 01:07:39,118 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-09-23 01:07:39,133 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-09-23 01:07:40,061 - octoprint.server - INFO - Shutting down intermediary server...
2019-09-23 01:07:40,437 - octoprint.server - INFO - Intermediary server shut down
2019-09-23 01:07:40,441 - octoprint.events - INFO - Processing startup event, this is our first event
2019-09-23 01:07:40,441 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-09-23 01:07:40,443 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-09-23 01:07:40,484 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-09-23 01:07:40,499 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-09-23 01:07:40,500 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-09-23 01:07:40,512 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-09-23 01:07:40,524 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-09-23 01:07:40,536 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-09-23 01:07:40,563 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-09-23 01:07:40,667 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-23 01:07:41,099 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-23 01:07:41,527 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:41,608 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:41,697 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:07:41,807 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:07:42,278 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-23 01:07:42,280 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-23 01:07:42,280 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-23 01:07:42,303 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-09-23 01:07:42,343 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-23 01:07:42,747 - py.warnings - WARNING - /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere/config.py:53: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
2019-09-23 01:07:43,268 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-23 01:07:43,600 - octoprint.plugins.anywhere - WARNING - {u'mjpeg_stream_tier': 6, u'UserId': 31638, u'camResolution': u'medium', u'name': u'My First 3D Printer', u'flipV': False, u'octolapseOptedIn': None, u'recordTimelapse': False, u'rotate90N': False, u'token': u'0U5I00DJTNSDHWBTLLQXT6UBB3RB2QKM', u'lastSeen': u'2019-09-23T00:10:29.900Z', u'flipH': False, u'updatedAt': u'2019-09-23T00:10:29.900Z', u'deletedAt': None, u'rotate90': False, u'id': 41985, u'createdAt': u'2019-09-08T15:14:02.129Z', u'subscription': u'free'}
2019-09-23 01:07:43,740 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.13', 'ram': 918188032, 'octopi_version': '0.16.0', 'version': u'1.3.11', 'pip': '19.0.1', 'cores': 4, 'freq': 1400.0, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'os': 'linux'}
2019-09-23 01:07:44,292 - octoprint.server.util.sockjs - INFO - User jkhood logged in on the socket from client fe80::c3e:ac66:cea7:29da
2019-09-23 01:07:44,659 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 9}
2019-09-23 01:07:49,743 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 49.09ms
2019-09-23 01:07:51,194 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 45.85ms
2019-09-23 01:07:53,868 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:11:59,311 - octoprint.server.util.sockjs - INFO - Client connection closed: fe80::c3e:ac66:cea7:29da
2019-09-23 01:11:59,859 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::c3e:ac66:cea7:29da
2019-09-23 01:11:59,933 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:12:00,219 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:12:00,327 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:12:01,107 - octoprint.server.util.sockjs - INFO - User jkhood logged in on the socket from client fe80::c3e:ac66:cea7:29da
2019-09-23 01:15:37,834 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:15:37,951 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 01:15:41,204 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 47.77ms
2019-09-23 01:19:56,569 - octoprint.startup - INFO - ******************************************************************************
2019-09-23 01:19:56,571 - octoprint.startup - INFO - Starting OctoPrint 1.3.11
2019-09-23 01:19:56,572 - octoprint.startup - INFO - ******************************************************************************
2019-09-23 01:19:56,640 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2019-09-23 01:19:56,706 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-23 01:19:59,964 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 26 hook handlers
2019-09-23 01:20:00,248 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-09-23 01:20:00,294 - octoprint.server - INFO - Intermediary server started
2019-09-23 01:20:00,296 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-23 01:20:00,923 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 26 hook handlers
2019-09-23 01:20:00,961 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-09-23 01:20:01,485 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-09-23 01:20:01,571 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-09-23 01:20:03,443 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-23 01:20:04,894 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-09-23 01:20:04,895 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-23 01:20:04,895 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-23 01:20:04,901 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2019-09-23 01:20:04,916 - octoprint.plugin.core - INFO - 17 plugin(s) registered with the system:
2019-09-23 01:20:04,936 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-09-23 01:20:04,945 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-09-23 01:20:04,960 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-09-23 01:20:05,911 - octoprint.server - INFO - Shutting down intermediary server...
2019-09-23 01:20:05,935 - octoprint.server - INFO - Intermediary server shut down
2019-09-23 01:20:05,938 - octoprint.events - INFO - Processing startup event, this is our first event
2019-09-23 01:20:05,940 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-09-23 01:20:05,942 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-09-23 01:20:05,983 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-09-23 01:20:05,996 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-09-23 01:20:05,998 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-09-23 01:20:06,012 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-09-23 01:20:06,023 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-09-23 01:20:06,033 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-09-23 01:20:06,053 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-09-23 01:20:06,114 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-23 01:20:06,905 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-23 01:20:06,975 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1569207417564 (fe80::c3e:ac66:cea7:29da) 20.81ms
2019-09-23 01:20:07,639 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-23 01:20:07,641 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-23 01:20:07,641 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-23 01:20:07,668 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-09-23 01:20:07,694 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-23 01:20:08,075 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:20:08,168 - octoprint.server.views - INFO - Preemptive cache not active for path /, ui _default and data {'query_string': 'l10n=en', 'path': u'/', 'base_url': u'http://octopi.local/'}, signaling as cached
2019-09-23 01:20:08,183 - py.warnings - WARNING - /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere/config.py:53: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
2019-09-23 01:20:08,241 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1569207418608 (fe80::c3e:ac66:cea7:29da) 14.12ms
2019-09-23 01:20:08,621 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-23 01:20:08,910 - octoprint.plugins.anywhere - WARNING - {u'mjpeg_stream_tier': 6, u'UserId': 31638, u'camResolution': u'medium', u'name': u'My First 3D Printer', u'flipV': False, u'octolapseOptedIn': None, u'recordTimelapse': False, u'rotate90N': False, u'token': u'0U5I00DJTNSDHWBTLLQXT6UBB3RB2QKM', u'lastSeen': u'2019-09-23T00:20:00.057Z', u'flipH': False, u'updatedAt': u'2019-09-23T00:20:00.057Z', u'deletedAt': None, u'rotate90': False, u'id': 41985, u'createdAt': u'2019-09-08T15:14:02.129Z', u'subscription': u'free'}
2019-09-23 01:20:09,134 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 01:20:09,165 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.13', 'ram': 918188032, 'octopi_version': '0.16.0', 'version': u'1.3.11', 'pip': '19.0.1', 'cores': 4, 'freq': 1400.0, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'os': 'linux'}
2019-09-23 01:20:10,402 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 9}
2019-09-23 03:57:12,502 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-09-23 03:57:12,614 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::c3e:ac66:cea7:29da
2019-09-23 03:57:12,705 - octoprint.server.util.flask - INFO - Passively logging in user jkhood from fe80::c3e:ac66:cea7:29da
2019-09-23 03:57:13,333 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 23}
2019-09-23 03:57:13,592 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 03:57:13,697 - octoprint.plugins.klipper - ERROR - Error: Klipper config file not found at: /home/pi/printer.cfg
2019-09-23 03:57:14,916 - octoprint.server.util.sockjs - INFO - User jkhood logged in on the socket from client fe80::c3e:ac66:cea7:29da
2019-09-23 03:57:40,276 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 46.02ms
2019-09-23 03:58:14,748 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 48.00ms
2019-09-23 03:58:15,427 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 47.55ms
2019-09-23 03:58:15,618 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 21.34ms
2019-09-23 03:58:15,885 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 21.51ms
2019-09-23 03:58:16,136 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 21.68ms
2019-09-23 03:58:21,404 - tornado.access - WARNING - 400 POST /api/connection (fe80::c3e:ac66:cea7:29da) 47.05ms
You read the installation instruction? Please read it...
Please Note: Klipper is only a helper program. Installation and config hat do be done via the command line.
You want to find a suitable printer.cfg file in the examples directory and copy it to your home...
Unless I've misunderstood the problem.
