unless you hack it or switch to another mainboard unfortunately no
sorry
sorry
how to "hack" it?
The usual way I guess. Find an exploit and use it ![]()
I'm no hacker - I can't help you with that part
Regarding the Kobra 2 Neo variant, stock firmware, connected with type-C cable and on a Raspberry Zero 2W:
Octoprint works out of the box with it generally speaking, but it throws back the following error message in the info tab:
" Info: Firmware Development Build
Your printer's firmware is a development build of Marlin (build date 20230816). It might be more unstable than a release version and should be kept up-to-date."
Anycubic didn't provide an updated firmware on their website, and I was unsuccessful in finding an up-to-date firmware for this printer, so if anyone can help with that, it would be appreciated, because I'd prefer full compatibility, just like I have with my Ender 3 Max. If it is a possibility of course.
This is not an error, it is prefixed with "info". It's information.
In this specific case, it is warning that your firmware was built from a development version of Marlin, and so you should watch out because you are more likely to run into bugs/issues from our experience. It has not detected any specific issues.
Semantics, the point is that not everything is working as well as it should, and tinkering is needed.
I sent the following to AnyCubic on 3/1/24:
Hello,
Having just read about the vulnerability with my Kobra2 Max print and
the MQTT cloud services, I would also like you to consider expanding
your Kobra 2 series architecture to allow lan management.
I am currently using the Anycubic application on Android and iPhone and
find them lacking and difficult to use. This is aggravated by the fact
that I cannot monitor my jobs and the printer using my desktop and
laptop computers. I am able to submit jobs to the printer using the
cloud service but that limits me to using the Anycubic slicer.
My Creality printer allows me to use Octoprint which provides me a rich
environment to monitor my printer, jobs and even submit them regardless
of the slicer I use. I am also not a super fan of cloud services for the
simple reason that it locks me in to your cloud service which may be
unreliable in the future and it exposes me to hacking like the MQTT
services issue we are all currently experiencing.
I love the large format printer, the pricing was excellent and the
support you give has been excellent. I just hope you will consider my
suggestion and open up your architecture a little to allow the users
more autonomous control of their printing environment.
I would love to discuss my issues if you feel that I may have valuable
input that fits within your long-term plan.
Thank-you.
Warmest Regards,
Here was their reply:
I hope this email finds you well.
The new firmware will addresses the issue you've encountered, is currently undergoing final refinements and will be available for download on the Anycubic official website starting from March 5th.
Furthermore, we have also incorporated the development of the local network control feature for managing printers into our ongoing projects. We appreciate your patience and eagerly anticipate its release.
Thank you for your understanding and continued support as we work to enhance our products and provide you with the best possible experience.
Should you have any questions or require further assistance, please feel free to contact us.
Best Regards,
ANYCUBIC Team
Keep your fingers crossed......
Yesterday I installed the Anycubic slicer v 1.41 and it has local wifi control over the kobra 2 max, I was here looking to see if anyone has figured out how to connect to octoprint like I do with my Vyper. At least i can now print to it over wifi directly instead of having to use their cloud. I heard that they were supposed to make orca slicer connect also but i have not got it to connect yet. I prefer to use use cura with the octoprint connection addon from the cura market place with the vyper and it works very well including the camera in cura to monitor it from cura, sure wish it worked that way with the kobra 2 max.
the Kobra 2 Pro series (which the max is a part of) are a part of Anycubics poor decision to lock down their hardware and firmware, such that you are increasingly more dependent on their infrastructure and Anycubic specific parts.
I mistakenly purchased a Kobra 2 Max after purchasing a Kobra 2, and found this out the hard way after realizing it would not be compatible with Octoprint.
I looked into Klipper as well, and that's not even an option because Anycubic has the bootloader password protected, even though the mainboard should be sufficiently new enough to run Klipper natively, and supposedly already runs a very modified, license-violating version of Klipper.
The only way to right these wrongs is to replace the mainboard with something that is open from the get-go. You also have to swap out the heatbreak to use standard volcano-style nozzles, as Anycubic in their infinite wisdom added a raised lip on the heatbreak and a boss on the end of the volcano nozzle, such that you are likely to have extrusion/leakage issues if you attempt to use a standard nozzle with it.
It's a shame because when I bought both printers, no other companies were selling lower-cost linear rail/linear actuator rod printers with all the other nice QoL features that the Kobra printers have.
There does seems to be some interesting hacks/workarounds for these printers, but yeah a board replacement with vanilla klipper would probably be the way to go.
