Just wanted to share some info about an upgrade available for C270 users.
I have several Logitech C270's that I have used for years -- it is a great, cheap, workhorse of a 720p webcam that works well with Octoprint. I have one on each of my Octoprint installations.
Because the C270 is ubiquitous, there are all sorts of printable mounts, cases, focus adapters, lens adapters, etc., available for it. The only downside is the 720p limit. I have wanted to upgrade to 1080p for a while but didn't want to re-engineer all my C270 accessories.
I HAVE GOOD NEWS!! Logitech has released what is essentially a 1080p version of the C270. The model is "Brio 101", and it uses the same case, same mount, same on-board lens holder, etc., as the old C270 -- but it is 1080P. The colors and exposure are a bit better as well. It is essentially a direct replacement for the C270: Just plug it in, change the resolution in config.txt, and restart.
The model is very new (I think Logitech released it ~Sept-25), and I cannot find specs for it on Logitech's website yet. Currently, searches only turn up info for the older "4k Brio" model. But the "Brio 101" is currently available for sale in multiple places (I bought mine from Amazon in the US, Amazon.com Brio 101 Full HD Webcam.
It's a perfect "drop-in" replacement for the C270, upgrading from 720p to 1080p. All my existing mounts and lens adapters for the C270 also fit the "Brio 101". It is only slightly more expensive than the C270, at around US$40.
Here's what v4l2-ctl says about it:
pi@octopi2:~ $ v4l2-ctl --all
Driver Info:
Driver name : uvcvideo
Card type : Brio 101
Bus info : usb-0000:01:00.0-1.3
Driver version : 6.1.21
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : Brio 101
Serial : 2327LZ52UUX8
Media version : 6.1.21
Hardware revision: 0x00009914 (39188)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Flags : default
Pad 0x01000007 : 0: Sink
Link 0x02000019: from remote pad 0x100000a of entity 'Extension 5': Data, Enabled, Immutable
Priority: 2
Video input : 0 (Input 1: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'MJPG' (Motion-JPEG)
Field : None
Bytes per Line : 0
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Rec. 709
YCbCr/HSV Encoding: ITU-R 601
Quantization : Default (maps to Full Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1920, Height 1080
Default : Left 0, Top 0, Width 1920, Height 1080
Pixel Aspect: 1/1
Selection Video Capture: crop_default, Left 0, Top 0, Width 1920, Height 1080, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 1920, Height 1080, Flags:
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
User Controls
brightness 0x00980900 (int) : min=0 max=255 step=1 default=128 value=128
contrast 0x00980901 (int) : min=0 max=255 step=1 default=128 value=128
saturation 0x00980902 (int) : min=0 max=255 step=1 default=128 value=128
white_balance_automatic 0x0098090c (bool) : default=1 value=1
gain 0x00980913 (int) : min=0 max=255 step=1 default=0 value=35
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=2 value=2
0: Disabled
1: 50 Hz
2: 60 Hz
white_balance_temperature 0x0098091a (int) : min=2800 max=7500 step=1 default=4000 value=4460 flags=inactive
sharpness 0x0098091b (int) : min=0 max=255 step=1 default=128 value=128
backlight_compensation 0x0098091c (int) : min=0 max=1 step=1 default=1 value=1
Camera Controls
auto_exposure 0x009a0901 (menu) : min=0 max=3 default=3 value=3
1: Manual Mode
3: Aperture Priority Mode
exposure_time_absolute 0x009a0902 (int) : min=5 max=2500 step=1 default=156 value=250 flags=inactive
exposure_dynamic_framerate 0x009a0903 (bool) : default=0 value=1
led1_mode 0x0a046d05 (menu) : min=0 max=3 default=0 value=3
0: Off
1: On
2: Blink
3: Auto
led1_frequency 0x0a046d06 (int) : min=0 max=255 step=1 default=0 value=0
pi@octopi2:~ $ v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
[1]: 'MJPG' (Motion-JPEG, compressed)
