I'm looking for an existing plugin that does this :
react to a GPIO pulse (button or anything sending an information)
trigger a shutdown procedure
ask for confirmation if a file is being printed, or the hotend is too hot
then toggle a GPIO pin if conditions are satisfied, or if the user confirms
optionally toggle this pin on a gcode and also if the printer is iddle after it cooled down, with a delay
I had no luck with PSU Control : I can read the sensing GPIO pin (confirmed by the navbar green bolt), but nothing happens... (I set switching option to a GPIO pin, and also tested a system command (sudo shutdown -h now). Nothing happens...
Does such a plugin exist ?
Should I develop my own ?
I don't think something quite that specific is created, but it may be possible with some clever scripting, or maybe with the 'Physical Button plugin' to read the button presses and 'do something'. Developers · kantlivelong/OctoPrint-PSUControl Wiki · GitHub
PSU control does list a set of helpers that other plugins can use, so it may be possible to write a simple plugin to go on top of it for the button sensing.
PSU control's sensing option is for sensing if the power supply is turned on or not, not for a button to control it.
Thanks !
Now I understand : PSU control is intended for a server that's running 100% of the time, and it manages the printer PSU only !
Browsing the plugins database, and their sources, I found a couple plugins that contain interesting code, and are simpler than PSU Control for a beginner :
OctoPrint-ShutdownButtonLEDBuzzer : does not ask for confirmation while prinnting ; I already do that with a input pin and dtoverrlay shutdown !
OctoPrint-Gpioshutdown : does the job, but the bells and whistles (user interaction) I want are missing ; it does not shutdown while printing, but does while the hotend is cooling down.
