Manual install 1.9.3 to existing rpi 4
I just did a manual install via python and then issued the serve command. Terminal is now locked in place. How do I invoke the service at boot and does that start up a web service?
Check out this guide
Or use an this installer which will create all needed services for you
(estimation) if your current user is not "pi" you have to adapt the configs
