Marlin EEPROM Editor python error
I have Octoprint installed on a laptop, Ubuntu 22.04, most plugins install with no problem, on previous install it worked fine, but when attempting to install the Marlin EEPROM editor on a fresh installation, I get this error:
Installing plugin "Marlin EEPROM Editor" from https://github.com/cp2004/OctoPrint-EEPROM-Marlin/releases/latest/download/release.zip...
/home/crypticprintz/OctoPrint/bin/python3 -m pip --disable-pip-version-check install file:///tmp/tmp2d2pz4is/release.zip --no-cache-dir
Processing /tmp/tmp2d2pz4is/release.zip
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'error'
error: subprocess-exited-with-error
Γ— python setup.py egg_info did not run successfully.
β”‚ exit code: 1
╰─> [18 lines of output]
/tmp/pip-req-build-v0vhnsq5/versioneer.py:521: SyntaxWarning: invalid escape sequence '\s'
] = '''# -- coding: utf-8 --
File "", line 2, in
File "", line 34, in
File "/tmp/pip-req-build-v0vhnsq5/setup.py", line 18, in
plugin_version = versioneer.get_version()
File "/tmp/pip-req-build-v0vhnsq5/versioneer.py", line 1950, in get_version
return get_versions()["version"]
File "/tmp/pip-req-build-v0vhnsq5/versioneer.py", line 1861, in get_versions
cfg = get_config_from_root(root)
File "/tmp/pip-req-build-v0vhnsq5/versioneer.py", line 438, in get_config_from_root
parser = configparser.SafeConfigParser()
AttributeError: module 'configparser' has no attribute 'SafeConfigParser'. Did you mean: 'RawConfigParser'?
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
Γ— Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Error!
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
Any ideas?
Apologies, the plugin is not yet compatible with Python 3.12. I really need to release that fix.
ok thanks for the info, it is a super useful plugin
Half a year has passed, is it still worth waiting for a solution to the problem?
Hello @sysanoo !
What's about helping to get a solution?
Eeprom editor don't install linux mint, octoprint, desk btt octopus v 1.1 h743
