Mars Firmware for Chituboard Compatibility
marsM3-firmware-for-chituboard.zip (921.4 KB)
Hi everyone!
I wanted to share this in case it is helpful for someone. On the Chituboard plugin for SLA printers, rudetrooper mentions that Elegoo Mars printers with the latest firmware may not be compatible. Indeed I found this to be the case and reached out to Elegoo for some support. They came back with a version of the firmware that successfully installs on my Mars (barcode leading with M3) printer and seems to mitigate some of the error messages that previously arose.
I am still having some issues using Octoprint, which I will post about shortly. However, if you have an Elegoo Mars and you are facing problems with Octoprint-Chituboard, I recommend trying this!
Best,
Mads
