So I'm sure I'll need @foosel or @kantlivelong on this one but I've converted the UFP plugin to use the internal module add_file to move the extracted gcode to the uploads folder rather than doing it with os module and am getting this error now. Was wondering if there is a way around this or not?
2020-04-28 10:26:43,901 - octoprint.filemanager.storage - ERROR - Error while writing .metadata.json to C:\Users\jneil\AppData\Roaming\OctoPrint\uploads
File "c:\octoprint\venv\lib\site-packages\octoprint\filemanager\storage.py", line 1583, in _save_metadata
f.write(to_bytes(json.dumps(metadata, indent=4, separators=(",", ": "))))
File "c:\python27\Lib\contextlib.py", line 24, in __exit__
self.gen.next()
File "c:\octoprint\venv\lib\site-packages\octoprint\util\__init__.py", line 1105, in atomic_write
shutil.move(temp_config.name, filename)
File "c:\python27\Lib\shutil.py", line 317, in move
os.unlink(src)
WindowsError: [Error 32] The process cannot access the file because it is being used by another process: u'c:\\users\\jneil\\appdata\\local\\temp\\tmpsc10ri'
The corresponding code that is causing the error I'm sure is setting the additional_metadata which happens here.
