I've got a Prusa MINI/+ (with a filament sensor) hooked up to a RaspPi 4B/2G running Octoprint 1.8.2. During my latest print the printer keeps stopping to eject/change the filament, like it ran out or was issued a M600 filament change. It first happened about 1-2 hours into the print, but now seems to happen every 10-20 minutes. I'm guessing that this is either:
- The filament sensor is having more trouble with this filament (I haven't used this particular filament before. Overture EcoPLA Midnight Black)
- that something is tickling the Simple Filament Change plugin.
My understanding is that #2 would cause the plugin to inject an M600 into the gcode stream, but I enabled serial logging and it doesn't seem to show that. Would the serial log/terminal actually show the M600?
I've disabled the plugin and the filament sensor to see if that fixes it, and if it does I'll try re-enabling the sensor to see if that re-introduces the problem.
