I'm finally getting around to setting up my system a bit better and wanted to add my Prusa to my home assistant. It is using Octoprint on a Pi Zero direct on board.
Everything setup well however the broker told me this.
1590240329: New client connected from 10.0.10.200 as 57qzPD8w7mq7wulIjeDYlX (p1, c1, k60, u'mqqt').
I had assumed that it would use the Hostname as a friendly name or something. I went all through the settings and could not find where I could give a friendly name, nor could I work out where this GUIDy thing is coming from. Is it possible to have a more meaningful name or am I stuck with this. Should I need to change the Pi or something (hoping for a more powerful Zero one day ;-)) will I then have to change everything else?
ta for any help.
