installation no problem but
first try, no changes
fhem Log
2019.04.20 10:11:25 2: autocreate: define MQTT2_3TNZHoUbNXtz8FvCoseuii MQTT2_DEVICE 3TNZHoUbNXtz8FvCoseuii
2019.04.20 10:11:25 2: autocreate: define FileLog_MQTT2_3TNZHoUbNXtz8FvCoseuii FileLog ./log/MQTT2_3TNZHoUbNXtz8FvCoseuii-%Y.log MQTT2_3TNZHoUbNXtz8FvCoseuii
after reboot
2019.04.20 10:22:37 2: autocreate: define MQTT2_3gliFh2LSFrsjJu4O9q1cF MQTT2_DEVICE 3gliFh2LSFrsjJu4O9q1cF
2019.04.20 10:22:37 2: autocreate: define FileLog_MQTT2_3gliFh2LSFrsjJu4O9q1cF FileLog ./log/MQTT2_3gliFh2LSFrsjJu4O9q1cF-%Y.log MQTT2_3gliFh2LSFrsjJu4O9q1cF
do i have first, something to configure?
octopi log
2019-04-20 10:22:15,167 - octoprint.startup - INFO - Starting OctoPrint 1.3.11rc3
2019-04-20 10:22:15,168 - octoprint.startup - INFO - ******************************************************************************
2019-04-20 10:22:15,588 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2019-04-20 10:22:15,705 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-20 10:22:19,972 - octoprint.plugins.errortracking - INFO - Initialized error tracking
2019-04-20 10:22:19,982 - octoprint.plugin.core - INFO - Found 26 plugin(s) providing 26 mixin implementations, 37 hook handlers
2019-04-20 10:22:20,371 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-04-20 10:22:20,429 - octoprint.server - INFO - Intermediary server started
2019-04-20 10:22:20,431 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-20 10:22:21,200 - octoprint.plugin.core - INFO - Found 26 plugin(s) providing 26 mixin implementations, 37 hook handlers
2019-04-20 10:22:21,252 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-04-20 10:22:21,848 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-04-20 10:22:22,457 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-04-20 10:22:25,837 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-04-20 10:22:27,629 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-04-20 10:22:27,631 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-04-20 10:22:27,633 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-04-20 10:22:27,639 - octoprint.plugin.core - INFO - Initialized 26 plugin implementation(s)
2019-04-20 10:22:27,662 - octoprint.plugin.core - INFO - 26 plugin(s) registered with the system:
| Action Commands (0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_actioncommands
| Automatic Shutdown (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_automaticshutdown
| Detailed Progress Plugin (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_detailedprogress
| EEPROM Marlin Editor Plugin (1.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_eeprom_marlin
| FileManager (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
| Firmware Updater (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| GcodeEditor (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GcodeEditor
| MQTT (0.8.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_mqtt
| Preheat Button (0.3.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
| Print History Plugin (1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_printhistory
| Slicer (1.4.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_slicer
2019-04-20 10:22:27,684 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-04-20 10:22:27,698 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-04-20 10:22:27,720 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-04-20 10:22:28,394 - octoprint.server - INFO - Shutting down intermediary server...
2019-04-20 10:22:28,741 - octoprint.server - INFO - Intermediary server shut down
2019-04-20 10:22:28,744 - octoprint.events - INFO - Processing startup event, this is our first event
2019-04-20 10:22:28,745 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-04-20 10:22:28,786 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-04-20 10:22:28,889 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-04-20 10:22:28,905 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-04-20 10:22:28,909 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-04-20 10:22:28,925 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "My Printer"' for _http._tcp
2019-04-20 10:22:28,939 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "My Printer"' for _octoprint._tcp
2019-04-20 10:22:28,951 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "My Printer" for SSDP
2019-04-20 10:22:28,965 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
2019-04-20 10:22:29,005 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-04-20 10:22:29,024 - octoprint.plugins.mqtt - INFO - Connected to mqtt broker
2019-04-20 10:22:29,043 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-04-20 10:22:29,613 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-04-20 10:22:30,743 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.34
2019-04-20 10:22:31,178 - octoprint.server.util.flask - INFO - Passively logging in user root from ::ffff:192.168.1.34
2019-04-20 10:22:31,204 - octoprint.server.util.sockjs - INFO - User root logged in on the socket from client ::ffff:192.168.1.34
2019-04-20 10:22:31,936 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-04-20 10:22:31,939 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-04-20 10:22:31,950 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-04-20 10:22:33,014 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://192.168.1.150/'}
2019-04-20 10:23:01,828 - octoprint.server.preemptive_cache - INFO - ... done in 20.53s
2019-04-20 10:23:01,829 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://octopi/'}
2019-04-20 10:23:09,863 - octoprint.server.preemptive_cache - INFO - ... done in 8.03s
2019-04-20 10:23:09,865 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.150/'}
2019-04-20 10:23:22,199 - octoprint.server.preemptive_cache - INFO - ... done in 12.33s
2019-04-20 10:23:22,201 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://octopi.local/'}
2019-04-20 10:23:29,752 - octoprint.server.preemptive_cache - INFO - ... done in 7.55s
2019-04-20 10:29:52,926 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.34
2019-04-20 10:29:53,728 - octoprint.server.util.flask - INFO - Passively logging in user root from ::ffff:192.168.1.34
2019-04-20 10:30:02,977 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.34
2019-04-20 10:30:03,148 - octoprint.server.util.flask - INFO - Passively logging in user root from ::ffff:192.168.1.34
2019-04-20 10:30:05,445 - octoprint.server.util.sockjs - INFO - User root logged in on the socket from client ::ffff:192.168.1.34
2019-04-20 10:30:20,963 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-04-20 10:30:21,139 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2019-04-20 10:30:21,142 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2019-04-20 10:30:22,154 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-20 10:30:22,180 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2019-04-20 10:30:22,196 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-20 10:30:22,211 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2019-04-20 10:30:22,216 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2019-04-20 10:30:24,816 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 1.1.8 (Github)"
2019-04-20 10:30:24,842 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2019-04-20 10:30:33,359 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2019-04-20 10:33:01,268 - octoprint.server.api.system - INFO - Performing command for core:reboot: sudo shutdown -r now
2019-04-20 10:33:01,500 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.34
2019-04-20 10:33:01,831 - octoprint.server - INFO - Shutting down...
2019-04-20 10:33:02,406 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-04-20 10:33:02,434 - octoprint.events - INFO - Event loop shut down
2019-04-20 10:33:03,532 - octoprint.server - INFO - Goodbye!
2019-04-20 10:33:15,675 - octoprint.startup - INFO - ******************************************************************************
2019-04-20 10:33:15,677 - octoprint.startup - INFO - Starting OctoPrint 1.3.11rc3
2019-04-20 10:33:15,681 - octoprint.startup - INFO - ******************************************************************************
2019-04-20 10:33:15,768 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2019-04-20 10:33:15,843 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-20 10:33:20,717 - octoprint.plugins.errortracking - INFO - Initialized error tracking
2019-04-20 10:33:20,727 - octoprint.plugin.core - INFO - Found 26 plugin(s) providing 26 mixin implementations, 37 hook handlers
2019-04-20 10:33:21,124 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-04-20 10:33:21,916 - octoprint.server - INFO - Intermediary server started
2019-04-20 10:33:21,918 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-20 10:33:22,696 - octoprint.plugin.core - INFO - Found 26 plugin(s) providing 26 mixin implementations, 37 hook handlers
2019-04-20 10:33:22,748 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-04-20 10:33:23,341 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-04-20 10:33:23,711 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-04-20 10:33:25,937 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-04-20 10:33:27,713 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-04-20 10:33:27,716 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-04-20 10:33:27,717 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-04-20 10:33:27,723 - octoprint.plugin.core - INFO - Initialized 26 plugin implementation(s)
2019-04-20 10:33:27,746 - octoprint.plugin.core - INFO - 26 plugin(s) registered with the system:
2019-04-20 10:33:27,771 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-04-20 10:33:27,786 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-04-20 10:33:27,808 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-04-20 10:33:28,489 - octoprint.server - INFO - Shutting down intermediary server...
2019-04-20 10:33:28,838 - octoprint.server - INFO - Intermediary server shut down
2019-04-20 10:33:28,841 - octoprint.events - INFO - Processing startup event, this is our first event
2019-04-20 10:33:28,843 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-04-20 10:33:28,857 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-04-20 10:33:28,889 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-04-20 10:33:28,956 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-04-20 10:33:28,958 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-04-20 10:33:28,975 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "My Printer"' for _http._tcp
2019-04-20 10:33:28,988 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "My Printer"' for _octoprint._tcp
2019-04-20 10:33:28,995 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "My Printer" for SSDP
2019-04-20 10:33:29,016 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
2019-04-20 10:33:29,057 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-04-20 10:33:29,077 - octoprint.plugins.mqtt - INFO - Connected to mqtt broker
2019-04-20 10:33:29,191 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-04-20 10:33:30,184 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-04-20 10:33:32,434 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-04-20 10:33:32,439 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-04-20 10:33:32,440 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-04-20 10:33:33,082 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://192.168.1.150/'}
2019-04-20 10:33:33,389 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.34
2019-04-20 10:33:33,564 - octoprint.server.util.flask - INFO - Passively logging in user root from ::ffff:192.168.1.34
2019-04-20 10:33:33,581 - octoprint.server.util.sockjs - INFO - User root logged in on the socket from client ::ffff:192.168.1.34
2019-04-20 10:34:00,897 - octoprint.server.preemptive_cache - INFO - ... done in 20.50s
2019-04-20 10:34:00,899 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://octopi/'}
2019-04-20 10:34:08,363 - octoprint.server.preemptive_cache - INFO - ... done in 7.46s
2019-04-20 10:34:08,365 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.150/'}
2019-04-20 10:34:21,885 - octoprint.server.preemptive_cache - INFO - ... done in 13.52s
2019-04-20 10:34:21,886 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://octopi.local/'}
2019-04-20 10:34:29,325 - octoprint.server.preemptive_cache - INFO - ... done in 7.44s
2019-04-20 10:41:24,347 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.34
2019-04-20 10:41:25,155 - octoprint.server.util.flask - INFO - Passively logging in user root from ::ffff:192.168.1.34
2019-04-20 10:41:40,194 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.34
2019-04-20 10:41:40,420 - octoprint.server.util.flask - INFO - Passively logging in user root from ::ffff:192.168.1.34
2019-04-20 10:41:43,939 - octoprint.server.util.sockjs - INFO - User root logged in on the socket from client ::ffff:192.168.1.34
2019-04-20 10:48:21,128 - octoprint.server.heartbeat - INFO - Server heartbeat <3
