Multiple octoprint instances in one webpage (html) using iframe doesn't work
I've used octoprint instances in one webpage.
It is very easy to upload and monitor 3d printers.
this is some part of the html code
> <iframe src="http://120.120.120.101" width="960px" height="1024px" topmargin=0 "frameborder="1" scrolling="yes">
> <iframe src="http://120.120.120.101:5001" width="960px" height="1024px" topmargin=0 "frameborder="1" scrolling="yes">
> <iframe src="http://120.120.120.101:5002" width="960px" height="1024px" topmargin=0 "frameborder="1" scrolling="yes">
The problem is ...
After updating into 1.4, they don't work anymore.
At the version 1.3 it did work well but after updating to 1.4 it each only works on independent webpage.
Is there any way to solve this problem?
Is it because of security issue to ban supporting iframe or frame function?
Sorry no..
Yep. Do this:
I really appreciate your answers I found the answer
The first way is a little bit difficult. I have multiple octoprint instances so i edited yaml files using the commands below.
nano /home/pi/.octoprint/config.yaml
nano /home/pi/.octoprint2/config.yaml
nano /home/pi/.octoprint3/config.yaml
nano /home/pi/.octoprint4/config.yaml
Almost at the end of the yaml file you will see "server:"part
server:
allowFraming: true <Add this part.
firstRun: false
incompleteStartup: true
The second one is a lot easier than the first one.
Thank you for all, I could get the solution because you.
