I created some information in case people with Windows, for example, have to use their printer's IP address in order to access OctoPrint.
Hopefully, this is useful.
I too have had problems with Windows when Bonjour is installed but I bit the bullet and installed Bonjour Print Services in order to use Octoprint. I have, in the past, edited the hosts file to add a pseudo DNS entry but this caught me out when the IP address changed. Of course this won't be a problem now that I have reserved the Raspberry Pi's IP address in DHCP.
Thanks for the reminder, I'll try uninstalling Bonjour later - when the current print has finished.
As a long-time I.T. Administrator, I can tell you that Bonjour on Windows isn't optimal. It seems to insert itself first in the driver stack and can prevent a Toshiba printer's correct drivers to be loaded when it's discovered, for example.
It's been many years since I experienced issues with Bonjour being loaded. In the end I had to remove all of Apple's apps before the problems disappeared.
