I cant seem to get this to work at all. I had a perfectly working Ender 3 on Klipper, with Octoprint 1.9 and octopi 1.0. Running on Pi 4b 8gb. just flashed it to the latest version like a week ago, LOL. All was well. As of now it only has a single Raspi cam v2. After flashing to this version, my camera does not work at all. In either setup, installed charlie_powell's plugin, and it shows nothing either. Obviously i am missing something. The camera streamer service seems to be running fine, but the -libcamera is not.
sudo systemctl status camera-streamer
â—Ź camera-streamer.service - camera-streamer
Loaded: loaded (/etc/systemd/system/camera-streamer.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/camera-streamer.service.d
└─override.conf
Active: active (exited) since Sun 2023-05-28 06:34:45 MDT; 41min ago
Process: 560 ExecStart=/usr/bin/camera-streamer-control start (code=exited, status=0/SUCCESS)
Main PID: 560 (code=exited, status=0/SUCCESS)
CPU: 48ms
May 28 06:34:45 octopi2 systemd[1]: Starting camera-streamer...
May 28 06:34:45 octopi2 camera-streamer-control[560]: Running start for camera-streamer-libcamera.service...
May 28 06:34:45 octopi2 camera-streamer-control[560]: ... done.
May 28 06:34:45 octopi2 camera-streamer-control[560]: /usr/bin/camera-streamer-control: line 56: /etc/camera-streamer.conf.d/usb-*.conf: No such fil>
May 28 06:34:45 octopi2 systemd[1]: Finished camera-streamer.
sudo systemctl status camera-streamer-libcamera
â—Ź camera-streamer-libcamera.service - camera-streamer libcamera
Loaded: loaded (/etc/systemd/system/camera-streamer-libcamera.service; disabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/camera-streamer-libcamera.service.d
└─override.conf
Active: inactive (dead)
May 28 07:12:26 octopi2 systemd[1]: Stopped camera-streamer libcamera.
May 28 07:12:26 octopi2 systemd[1]: Starting camera-streamer libcamera...
May 28 07:12:26 octopi2 systemd[1]: camera-streamer-libcamera.service: Control process exited, code=exited, status=1/FAILURE
May 28 07:12:26 octopi2 systemd[1]: camera-streamer-libcamera.service: Skipped due to 'exec-condition'.
May 28 07:12:26 octopi2 systemd[1]: Condition check resulted in camera-streamer libcamera being skipped.
May 28 07:12:36 octopi2 systemd[1]: camera-streamer-libcamera.service: Scheduled restart job, restart counter is at 10.
May 28 07:12:36 octopi2 systemd[1]: Stopped camera-streamer libcamera.
May 28 07:12:36 octopi2 systemd[1]: camera-streamer-libcamera.service: Start request repeated too quickly.
May 28 07:12:36 octopi2 systemd[1]: camera-streamer-libcamera.service: Skipped due to 'exec-condition'.
May 28 07:12:36 octopi2 systemd[1]: Condition check resulted in camera-streamer libcamera being skipped.
sudo systemctl start camera-streamer-libcamera
└─override.conf
Active: activating (auto-restart) (Result: exec-condition) since Sun 2023-05-28 07:18:27 MDT; 5s ago
Process: 6436 ExecCondition=/bin/sh -c /usr/bin/libcamera-hello --list-cameras | grep -o '/base/soc/[^)]*' (code=exited, status=1/FAILURE)
CPU: 94ms
Running latest Klipper, Moonraker and Klipper screen, again all was well before upgrade. It seems like the plugin itself is working, just not getting a stream.
Couple other things, this is all a fresh install of everything. I flashed Octopi, update, upgrade, install Klipper, install Moonraker, install Klipper screen, install plugins, configure plugins. Check for updates and upgrades again. test.
octoprint-systeminfo-20230528141604.zip (146.4 KB)
