When I install a plugin, there is an error "ModuleNotFoundError: No Module named 'apscheduler'". I tried to install the plugin via Octoprint's Plugin Manager and manual method, but neither worked and the same error was shown. Plus, I tried to install APScheduler in different locations, such as the base, in raspberry pi. But None of them worked, and same error.
2021-03-16 02:53:02,811 - octoprint.plugin.core - ERROR - Error loading plugin CMfgDataAcquisition
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 1298, in _import_plugin
module = _load_module(module_name, spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 69, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 238, in load_module
return load_package(name, filename)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 212, in load_package
return _load(spec)
File "<frozen importlib._bootstrap>", line 696, in _load
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_CMfgDataAcquisition/__init__.py", line 13, in <module>
from apscheduler.schedulers.background import BackgroundScheduler
ModuleNotFoundError: No module named 'apscheduler'
OS: Linux
Raspberry model: Raspberry Pi 4 Model B Rev 1.2
Octopi_version: 0.18.0
OctoPrint_version: 1.5.2
python: 3.7.3
