No more working Filament Sensor Plugin for Octoprint?
I really need to have a filament sensor connected to my UMO+ but after some reading here I got the impression, many filament-sensor plugins for Octoprint do not work any more!
Ist that true and if so, can someone please point me to a plugin that really IS working?
The type of sensor wouldn't matter as I still haven't got one yet. So I'm still free to choose.
So far I have just searched the net for information.
N/A
Complete Logs
No Logs available
OctoPrint Version 1.3.11, Ultimaker Original+, Windows 10, Firefox
Hello @basteluwe!
This should run quite well:
Some of them may not be compatible to 1.3.11 anymore, this could be another of your issues. Maybe you want to try updating?
Thanks for your replys so far.
Actually I was reading this very long topic about filament sensors and at the end someone suggested Enclosure-Plugin would do the job. But others said, they tried and it didn't work either.
Well, I guess I have to try for myself.
And yes, updating the OctoPrint SW seems a good idea!
Rgds Uwe
I have just setup Filament Sensor Simplified v0.2.0 which works well. Note if you have tried v0.1.0 I would uninstall then reinstall v0.2.0 as I had a problem upgrading.
I am doing whatever it takes not to simply run long wires to any fan headers in the worker expecting the walled in area module could deal with it by then!
I have recently added a runout sensor (just using a micro switch) to my Ender 3. I have a description of what I did and used here:
So far it has worked without any issues.
