After updating to 1.5 when I start a print a print terminal gives me "Changing monitoring state from "Operational" to "Starting""
But then nothing
Do you use the gcode leveling plugin? If you try to disble it.
If that doesn't help try the safe mode to rule out other plugins.
We need the logs (octoprint.log and serial.log) in order to help you if it isn't a plugin related problem
Also, if you have OctoLapse, that will need to be updated to the prerelease version or disabled.
Also: logs. We can only guess without them...
Thanks, Charlie,
I installed Octolapse-0.4.1rc.zip and that seems to work!
