No Snapshot Trigger with Artillery Genius
Good morning!
I am having trouble getting the Octolapse on the Artillery Genius and running.
The normal time-lapse recording from Octoprint works itself, the camera is also set up correctly.
Cura: 4.13
Octolapse: 0.4.1
OctoPrint: 1.7.2
As described in these instructions, I added the script from this page to the start of the Gcode.
My problem now is that I don't get any snaps even in test mode.
Even the preview does not show anything, so the trigger to trigger the snap is simply missing.
If I set the trigger to "Smart GCode", I also get an error message that no snapshot commands are included.
No snapshot commands were found. Current snapshot commands: @OCTOLAPSE TAKE-SNAPSHOT
But how does it work to generate this command?
I guess that it should be in the Gcode?!
The trigger via a timer does not work either, so I suspect something in the Octolapse Settings rather than in Cura ....
image|690x273
So I think I've got it!
  1. In the firmware settings I MUST have X/Y/Z mode set to "Default To Absolute". This is the default setting!
  2. Then the priming is initially not recognized for me (error)
  3. To get rid of that I had to raise the prime height from 0.75 (default) to 0.85
