I have an Ender 3 v2 that I bought second hand with mods already installed: a Voron Afterburner and a BL Touch sensor for auto levelling. I have set it up with an RPi and Octoprint. According to some video I watched when doing the initial setup, there's an issue with back power(?) and I needed to have a data only cable (which doesn't exist) and so I modified (mangled) a power+data cable to only send data. I also added ferrite cable cores to it.
Now to the problems...
Constant Kill Commands
The above setup worked fine for about a month. Then, out of the blue, it started sending (receiving?) constant kill commands and needing to be turned off and on again. For a while, choosing a lower baudrate instead of AUTO seemed to solve it, but now that doesn't work. Correlation is not causation? No idea what makes it unhappy, but it has a seizure about every 3 attempts to print, and sometimes 3-4 times in a row within ten minutes before deciding it'll stay happy and warm up.
I would love to not use a DIY mangled cable, if someone explained where to get a cable that worked without causing/allowing the back power issue to happen. I don't even know if the constant Kill commands are related to the cable or not. It just seems sus.
Printing in the air
Every time I level the bed and set a new mesh, then start a new print, it decides that Z 0.00 is a new plane about 3-4mm above where I just set it, and just starts printing in the air. Re-levelling the bed to that new height does nothing; the next attempt is just 3-4 mms higher yet again. I am shortly going to run out of levelling screw length. What gives? Why does it keep deciding the earth has changed altitude? Is this an Ender issue, or a BT issue? (I know it's not an Octoprint issue, I just have no idea where else to cry for help)
Octoprint threw me a kill error relating to the BT Touch but I think it must just be relaying what the error was that the printer sent it?
Server started in Safe Mode?
Octoprint showed me this orange dialog box for a while, and no other information relating to the "problem" that caused it to start in safe mode. I have no idea what that entails other than that 3rd party plugins apparently won't work. Not knowing what else to do about it, I just ssh'd into it via Terminal and rebooted. vOv
