I remember making a change lately in my printer's Settings -> Filters screen, pressing the Save button having done so. I'm pretty sure I was trying to adjust the temperature filter, I'd guess.
plugins:
_disabled:
- forcelogin
serial:
additionalPorts:
- /dev/smoothieboard
autoconnect: true
temperature:
profiles:
- bed: 100
chamber: null
extruder: 210
- bed: 60
chamber: null
extruder: 180
terminalFilters:
- name: Suppress temperature messages
regex: '(Send: (N\d+\s+)?M105)|(Recv:\s+(ok\s+((P|B|N)\d+\s+)*)?(B|T\d*):(-)?\d+)'
- name: Suppress SD status messages
regex: '(Send: (N\d+\s+)?M27)|(Recv: SD printing byte)|(Recv: Not SD printing)'
- name: Suppress wait responses
regex: 'Recv: wait'
webcam:
ffmpeg: /usr/bin/ffmpeg
snapshot: http://127.0.0.1:8080/?action=snapshot
stream: /webcam/?action=stream
What I see, though, is that the indentation levels of the children of terminalFilters appear to be one level too high.
The earlier temperature.profiles's children all have 4 + hyphen + 3 + entry as a format. terminalFilters's children have hypen + 3 + entry.
serial.additionalPorts's children have 4 + hyphen + 1 + entry format. plugins._disabled's children have 4 + hypen + 1 + entry format which again, to me, looks like it's one indentation level too high.
The documentation for adding custom controls suggests this:
controls:
- name: Fan
layout: horizontal
children:
- name: Enable Fan
type: parametric_command
command: M106 S%(speed)s
input:
- name: Speed (0-255)
parameter: speed
default: 255
- name: Disable Fan
type: command
command: M107
I note that the documentation includes two-space indentation levels and my own config.yaml has four-space indentations. I know that I have personally copied/pasted straight from the docs in the past for modifying my own file. I recently just did a PR against OctoPi for a config.yaml-configuration script in which I'd gotten the indentation level wrong. I note also that the accessControl.localNetworks's children also have this listing indentation that's unexpected to me.
I guess I'm looking for some guidance here. The hyphen-list indentation syntax appears to be somewhat consistent in the documentation¹ but not-as-consistent in implementation. I was just about to help someone with a config.yaml formatting problem but I realize that I don't know how lists are supposed to be indented.
- See the controls section documentation which doesn't necessarily agree with the others
