Octolaps: Can't get it to work after last update
Hello,
This plugin worked just fine before but after the latest update it just don't work.
I have a Wanhao i3 v2.1 and tested all of the X/Y/Z axis mode and non of them works.
Home/Mesh Bed Leveling Position is set to auto,, it could be something there that b/c if I use absolute or relativity settings it keeps spamming about not knowing the home pos.
Do you wish tio have any log files?
Edit: Changed the settings to "Default to Absolute" on both E and XYZ then removed the Auto-Detect setting.
and left the XYZ values blank, Looks like it's working better now.
Edit2: Try run looked Ok but I didn't see that that the printed started 1 mm above so a normal print failed
I personally run an X/Y home plus a Z home on the Control tab every time I startup my printer, just to be safe.
What happens if you do each of those and then retry?
It's set to Default Absolute, removed Auto-Detect setting för home pos helped me.
Now it's a plugin in Cure that is messing with me.
Cool. Please mark this as solved. (There's an icon somewhere on here...)
Only the person who initiated the thread can see that icon and mark it as solved.
